L
lozzy
I had a Worcester 28CDi recently replaced with a Main EcoElite Combi Boiler and ever since installation is loses pressure every 3/4days.
With the old Worcester we occasionally lost pressure, butmaybe once or twice every 6 months at most. The old boiler only seemed to startlosing pressure (as far as we were aware!) when we had had a gas leak and hadthe gas rerouted instead of under the floor it was taken up and through theloft space and back down to the boiler.
The Worcester was old so we got it replaced a couple ofmonths ago, but ever since then the Main Eco boiler seems to lose pressure alot quicker than the Worcester did! We top it up to between 1-1.5 and it isfine, then over night seems to cut out as it's dipped below 0.5. (We've noticedit tends to be after we've done the washing up in the evening! But obviouslydon't notice it until the morning when we need a shower!)
A couple of the radiator thermostatic valves have previouslyhad small leaks, which we have fixed with some tape and tightening etc andwe've had the plumber out who fitted the new boiler to take a look to see ifthis is the issue but he seems to think the leak is under the floorboards andsaid we should just live with it and keep topping it up. We obviously aren'thappy with this opinion but also don't want to start ripping up the woodenflooring without cause either.
We've bled the radiators too just in case it was that.
There are no visible signs that the pressure relief valve isleaking outside either.
Is there anything to suggest before I go down the route ofseeing if my insurance offer a leak tracing service!
Thanks in advance
Thanks in advance
