View the thread, titled "Boiler Not Igniting?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I have a Sabre HE boiler about 10 yrs old with a curious problem?
I usually go through the following ordeal with my boiler :
I switch it from the middle position which resets the boiler to the left position which switches on the central heating and hot water.
It usually works fine for a few weeks but then breaks down. I leave it for a week or so then try it again and it usually works fine again for another
few weeks before breaking down again?
After looking at this problem I see the pilot light isn't coming on. I'm not sure whether the pilot light isn't lighting or the gas isn't getting through somehow?
I'm stumped on why it works for a few weeks then breaks down. You leave it for a bit of a rest then it appears to work again. Why?
Can we have a picture of the boiler and buttons please mate. Your timer and stat as well please.
Here you go I send you a few pictures. Hope they are what you need.
are you gsr ? because most of the solutions on here are going to require this.But as its zfriday maybe we can do the basics
Centralheatking
is this one electric ignition ?
if not its the coupler
centralheatking
centralheatking
Not sure, but I send you some pics of inside if they help. I guess the long white stick is the ignition? I'm guessing its electric?
As far as I see its either the gas isn't getting through or the ignition isn't sparking?
Reply to the thread, titled "Boiler Not Igniting?" which is posted in Boiler Advice Forum on Plumbers Forums.
