C
cjyoung
Hi all,
I'm a complete novice when it comes to plumbing & central heating systems so please bear with me... 😉
We have a Glow Worm Flexicom 15hx boiler (located in the kitchen) which was installed just under four years ago. During the time we've had the boiler we've had a number of occasions when we've experienced a loss of hot water and central heating. We symptoms always seem to be the same: the boiler appears to operate correctly but when the burner comes on the indicated temperature rises quickly from ~45 deg C to the required temperature of 70 deg C at which point it shuts off. The burner is only active for about 45 seconds which, I guess, is not really long enough to heat the water properly. I'm not sure how reliable the temperature readout actually is. The net result is that the radiators either don't heat up at all or become lukewarm and the same is true of the water in the hot water tank. We often find that the pump gets very noisy after about 15-20 minutes of operation as well (this may or may not be related).
We've had the original installers out a number of times and have had a replacement pump and new hot water tank as a result. Both 'solutions' sorted the problem for a period of time but now it's resurfaced again. Does anybody have any suggestions as to what the cause of the problem could be? I'm reluctant to have to call the installers again because every time we do it seems to cost hundreds of pounds without actually resolving the problem.
In case it makes any difference I've bled all the radiators (two upstairs, two downstairs and one towel rail in the bathroom) and there is no (apparent) air in any of them. That's about the limit of my 'expertise' I'm afraid!
