Boiler pressure on EcoTec keeps rising
View the thread, titled "Boiler pressure on EcoTec keeps rising" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi All, I have a problem with my 10 year old EcoTec boiler. The pressure keeps rising to over 3 bar every few days. To get it running again I am releasing about a cupful of water from a radiator to get it below 3 bar. The filling loop is disconnected and I’ve noticed water from the pressure relief valve. Where is the water coming from? Any ideas please.
Which ecoTec?
It could be via a secondary heat exchange of some sort. e.g. coil inside a cylinder?
Depends on the installation you have.
EcoTec plus 624 as part of a sealed system with large hw cylinder.
Could be a hole in the coil. If the water pressure (I'm presuming unvented mains fed cylinder) is higher than the heating system, it will rise to equalize.
A Plumber will be able to diagnose whether that is it or not. If it is, you will need a new cylinder. Don't get one too big, there's no point.
I’m only releasing a little water to get it below 3 bar, probably should get it down to 1.5. To answer your question it will stay above 3 (3.4 is the highest I’ve seen) until I release the pressure, boiler automatically cuts out when too high. I first noticed this when the hot water went cold, the boiler had a fault code (can’t remember the code) and the pressure was high, resetting and releasing pressure got it going again. The tank is a Stelflow 210L
You might have a EV (expansion vessel) problem, it may have lost or partly lost its precharge pressure, suggest reducing the cold pressure to 1.5bar, it certainly won't take 3 days to rise to 3bar on system reheat if this then is the problem.
Reply to the thread, titled "Boiler pressure on EcoTec keeps rising" which is posted in Boiler Advice Forum on Plumbers Forums.
Jimbo376,
John.g,
