boiler problem (help please)
View the thread, titled "boiler problem (help please)" which is posted in Boiler Advice Forum on UK Plumbers Forums.
J
joiner wayne
Hello i recently posted a thread regarding my leaking Trianco Redfare anthrocite solid fuel boiler to which i have used the Dunsley oxypic.
I have followed the instructions to the letter.
Firstly i drained down the central heating side.
then i applied fernox F3 cleaner via the central heating header tank filled the system back up lit the fire and bleed all the rads. and left this running for 24 hours (rads all worked fine)
The next day i drained the system again and flushed it out keeping the header ball cock free.
I then filled the system back and used the dunsley oxypic via the header then again bleed all rads and worked fine think even the leak has disappeared.
My problem is why have i got the oxypic coming through my hot water taps.
The header tank is the central heating one it is in the attic attached to the side of the hot water tank even the hot water tank is full of the oxypic now.
What have i done wrong
Looks like the coil in the cylinder is holed as well, looks like it might be time to get a profesional in
Reply to the thread, titled "boiler problem (help please)" which is posted in Boiler Advice Forum on Plumbers Forums.
joiner wayne,
joiner wayne,
