View the thread, titled "boiler problem" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Some help needed, Glow worm compact 100 fanned flue system boiler is working, but cuts out before the room temperature has been reached. Initially i thought room stat but as the boiler cuts out, it makes a winding down noise that, although not loud, sound like an aeroplane falling from the sky. The house is set up with 2 identical boilers, 1 serving heating to upstairs and hot water, with the other serving heat to downstairs only or vice versa. the operation between the 2 can be easily compared with them being side by side.
I haven't done too many tests on the problem boiler as electrical results seemed ok, maybe due to the fact that the boiler tachnically still works.
Any advice much appreciated
Simon
its been a couple of weeks since ive been at job, so bit hard to remember, i dont think it is condensing, if i was wrong could it have something to do with it
if its a condenser you do get funny noise,s if co/co2 ratio is out need to do fga test
Reply to the thread, titled "boiler problem" which is posted in Boiler Advice Forum on Plumbers Forums.
