View the thread, titled "Boiler Programmer" which is posted in Central Heating Forum on UK Plumbers Forums.
I have a wall mounted thermostat which is connected to a 26 volt supply from my Glowworm 24ci boiler.
I would like to replace this thermostat with a programmer so i can time when the heating comes on and off.
Currently the heating is turned on/off using the thermostat.
Can the thermostat be replaced with a programmer that works off this 26 volt supply or is a mains supply required.
Any suggestions which programmer i should use.
Thank you
You can uses any thermostat that is 24v rated.
All the thermostat is, is a switch.
So search for any 24v programmable thermostat
Reply to the thread, titled "Boiler Programmer" which is posted in Central Heating Forum on Electricians Forums.
