View the thread, titled "Boiler pump keeps running" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hey what could be causing a combi boiler pump to keep running all the time?
Like the man says it might be the pump relay on the PCB, I would call the manufactures and ask is the pump run on time based or temperature, if its temperature it might be a sensor, you didn't say is this an old problem or only just started
So it could be an electical fault? My boss said somthing and putting a bye-pass in but can't see how this would cure anything?
No I don't get it? Like said, maybe there is some kind of pump over run that's triggering it. Check sensors
Reply to the thread, titled "Boiler pump keeps running" which is posted in Boiler Advice Forum on Plumbers Forums.
