I’m hoping someone can advise who would be best to fix the issue we are having.
We have multizone central heating, with a separate hot water tank. Recently had hive installed but this issue has happened once before we had the install. The electrician who did the install has already had to come back once as did something wrong as when we put the hot water on, the radiators came on (he admitted he’d not done a hive multizone before) so not sure if it’s the hive causing the issue or something else.
Boiler won’t stop running. Even when, according to hive, everything is off, it just keeps running.
I’ve checked the valves and they are all switched to auto. The radiators are not hot when it’s doing this, so I know the valves are closing (although not sure how to check if the hot water is heating or not).
Radiators will heat up at the scheduled time, so no problems there. It’s just the boiler not switching off when it’s being required to heat anything.
We really struggled to find someone to do the hive install in the first place so just want to make sure we are getting the right person out this time who can fix the problem.
We are in wakefield, w.Yorkshire if anyone can help!!
