View the thread, titled "Boiler screeching noise" which is posted in Boiler Advice Forum on UK Plumbers Forums.
J
James Calow
I have a vokera excell 80sp boiler. I get hot water and heating fine just as expected. I have had two diaphragms replaced over the last 8 years when I have had it serviced.
My concern and issue is that when the heating is on the boiler can sometimes emit a high-pitched squealing sound. There is no consistency to it, occasionally there is no noise at all, sometimes it is more of a rumble and then at other times it can be very loud and high pitched.
When it is screeching if I turn on a hot water tap the noise stops instantly all the time the tap is running. When I turn the tap off sometimes the noise will not start up again for many minutes if not hours, but other times it will return immediately.
Does any one have an idea of what it could be and if I could fix it my self, I am reasonably competent with a spanner.
more likely you wil flodd yourself out if you dont have appropriate replacement orings etc to hand and then you will flood the pcb, which will need replacing
Whatever it is you need a GSR, mess with these things and they could kill you !!
Thanks- I'll leave well alone. Any ideas what could be causing it so I can give the engineer a heads up when I call him?
Reply to the thread, titled "Boiler screeching noise" which is posted in Boiler Advice Forum on Plumbers Forums.
