View the thread, titled "Boiler settings" which is posted in Boiler Advice Forum on UK Plumbers Forums.
StuartDavis
Hi
I have a Baxi condendsing boiler (5 years old) - recently I had to get the sundial Y-valve next to the hot water tank replaced as it had failed (and fused in the timing control panel).
At some point, my plumber must have changed the settings on the Baxi boiler, as now it cycles and heats HW even when outside of the pre-set programme times, and also even when HW and CH are switched to OFF on the control panel. Even turning the boiler switch off does not prevent it heating up water. I've heard that there is a way of overriding this, similar to factory-preset I guess, so that it will only switch on at the times I request.
Any help would be much appreciated.
Thank You
Reply to the thread, titled "Boiler settings" which is posted in Boiler Advice Forum on Plumbers Forums.
