Hi guys, hope some bright person on here can shed some light on the cause of this problem.
I did a gas safe check on a Ravenheat Primary AAA on Wednesday and had to replace the gas valve yesterday due to it passing on lockout. As usual, before working on an appliance I checked the basic operation to ensure it fired up on demand etc. System is Y plan open vented. On completion of replacing the gas valve I switched on CH and HW demand and the boiler ran perfectly. After half an hour I switched off CH demand but left the HW demand on. After 10 minutes the boiler suddenly shut off. The kind of shut off that sounds wrong. The lock-out light did not illuminate. According to MI's this warning lamp should light on flame failure or overheat. I know the bulb works in the lockout warning lamp as it illuminated on flame failure while re-checking safety device. Before doing anything else I re-energised demand for CH but the boiler was dead. Still with demand for CH only I switched the boiler's main switch off and then back on and it fired up. I switched on the demand for HW but within 30 seconds the boiler stopped again. Reset again and tried on CH only and it ran normally. After half an hour I switch demand for HW and it stopped again! I'm thinking flow problem on DHW; either restriction in primary pipes, possibly the 3 port valve is not opening fully on HW demand only, or maybe faulty Overheat stat (but why doesn't the lamp illuminate?) I don't know if it is anything to do with the way the pump is wired as the boiler needs pump over-run. The Mi's shows the pump wired directly back to a dedicated pump connection on the boiler when using Y plan. The pump does over-run but this appears to be taken care of in the control centre.
Can anyone help solve the problem please?
