R
RGP
I hope someone can shed some light on a strange problem I'm having with my boiler.
We have a wireless thermostat to control when the heating should come on. In the morning the boiler fires up and everything works as it should most of the day. However, at some point in the evening even though the boiler control is still set to ‘on’ and the thermostat is telling the boiler to fire (and the control unit is receiving this signal and looks to be passing it on), absolutely nothing is happening. The boiler doesn’t try to fire, and it isn’t showing any faults – it’s as if it isn’t being asked to fire. If I turn the hot water to ‘on’ it fires up correctly.
The next day the boiler will start up again in the morning and the cycle repeats itself each day.
When we have been away for the weekend I have changed the thermostat so that the heating only comes on for a few hours in the evening to warm the house up before we get back. This seems to work OK. I can therefore only assume that during the course of the day some effect is building up until eventually the problem manifests itself, and then overnight the effect wears off.
We have just had the boiler serviced and they found no problems with it. Given that it fires if I turn the hot water on I can only assume that there is a problem with the control box which takes the signals from the thermostat and the boiler control unit. However, I don’t know what on earth it could be.
Any help or suggestions would be gratefully received. If specific details are needed please let me know.
Thanks in advance
Richard
Thanks in advance
Richard
