I have just upgraded my parents heating system to an unvented type and fitted new Vaillant EcoTec Plus 637. Its quite a big bungalow they are moving into so hence the large boiler. I've fitted a 210 ltr unvented cylinder it was the max height I had. In their existing house they had a Valor Stove fire which they really liked as it gave out allot of heat. They wanted me to install this in the new place which is fine so i built them a false chimney. They have now decided that as the energy bills are going up they wanted to save any way they could so i have looked into fitting a "boiler stove" instead of the standard stove fire they have. As this is the first one i have fitted I’m a bit unsure on how to connect it into the new unvented system so that both can work together. The boiler stove they are looking at is the Stovax - Stockton 11HB which gives out a nominal 7Kw to the room and 11Kw to the heating circuit.
Any help would be much appreciated
