Feb 7, 2014
169
Hey guys
Few months ago I had a problem with my glow worm betacom 30c when running the hot tap it’ll get lukewarm then cold and would keep doing this till the boiler timed out
British Gas sorted it after the 4th visit. Now few months later (not sure if the cold weather has made it worse) the water doesn’t stay hot. It goes from hot to lukewarm then back to hot. It’s like the boiler can’t keep a constant flow of hot water.
Any suggestions what it could be? Tempted to get British Gas back out but will they say it’s a fault even though there’s still hot water ?
Thanks guys
Get em back out you have a partial blockage which needs clearing . Kop
Not supposed to give advice on the open forum related to gas boiler repairs bud you have diagnosed the problem in your question slacky ? think of how your boiler heats the water and you have your answer . Tkop
Reactions: Old Account
Heat exchange? Would this affect the central heating ? I think I’ve read somewhere heating and hot water run through different parts of the heat exchange
When the boilers running it keeps going round in cycles. You hear it fire up pilot light ignites runs for 40-50 seconds then starts again. Is this correct? I’ve never noticed this before but can’t say I’ve been listening out for it
Central heating is normally ok hot water delivery is the problem . Kop
No it should not as I said you have a partial blockage where it is will need to be determined by your british gas engineer sorry I can't be anymore help
