Looks like an old itt gas valve from an old glow worm space saver
As to the Identifying there should be a data badge on it inside! Did you take the case off even?
Just cap it off, with the marks up the wall it will be pretty sooted up on the hex
I couldn't take the front cover off as a big chunk of the kitchen would have came out, so as soon as I see/felt the front cover & the soot up the outside wall I capped it off. The custard has said it was only be 12-24hr like that, but she did say she was felling ill when the boiler was on. In my eye's it was showing big signs of CO & not wanting to take any risks it got capped there & then....
I'v got to price up for a new combi ASAP, but every thing I need is at the wrong side of the house i.e gas meter, airing cupboard, outside wall. It's gonna be a pain in the harris type job.
So are we all agreed that it's 4 pipes gravity flow & return & pumped heating flow & return????
Thanks people, it makes things so much easier being part of this forum....
Could put in a 4 pipe system boiler instead and retain hw cylinder.
Veismann
Hope you classed i as ID . It's obviously burning badly/stroke dangerously with that amount of soot on the wall. That's why the casings so hot. Easiest option is normally for the combi to go in the airing cupboard on these type of jobs. Oh and it's deffinately gravity with four pipes and the pump there. Fitting a system boiler would be a lot more work due to having to install a divertor I the airing cupboard.
Reply to the thread, titled "Boiler/System ID please people" which is posted in Boiler Advice Forum on Plumbers Forums.
