M
ma701ss
Hi my British Gas 330 boiler has a radiator dial on the front with temp reading below of 52 degrees. What should I set this to 60, 80, etc.? Is it the flow temp?
Is your place warm enough?
Ok will try as above. Yes the room stat is in the hallway which tends to be coldest so have to set to 15 degrees or so otherwise the house eta too hot.Do you have a room stat?
Yes but I'm not sure if it should be set to a certain temperature for some reason, and then control with TRVs if too hot? What's standard?
If you're warm enough then don't touch anything!
Yes, it's the flow temperature. This needs to be about 70-75C so the water in the HW cylinder gets heated to 60C.Hi my British Gas 330 boiler has a radiator dial on the front with temp reading below of 52 degrees. What should I set this to 60, 80, etc.? Is it the flow temp?
Reply to the thread, titled "Boiler temperature reading" which is posted in Boiler Advice Forum on Plumbers Forums.
