panikmkanik
can anybody explain as to the difference between combi, system and heating boilers
heating boiler is used with a cylinder to give heating and hot water usually run open ventedcan anybody explain as to the difference between combi, system and heating boilers
all boilers for domestic use are condensingcombi heat only or systemcheers steve!the question is whether to go for combi or condensing and where i can get more info
you are going to have to fit condensing boiler condense can go into any plastic waste pipe, sink ,basin etc or the condense can be pumpedcheers again! presently got open vented system with cylinder and header tank and f & e in flat where running condense would require pump as long run to stacks and property backs on to pavement and busy main road.
present boiler is crappy apollo which needs to be fired into outer space!!!!!!
Reply to the thread, titled "boiler types" which is posted in Boiler Advice Forum on Plumbers Forums.
