Afetrnoon,
I have had a new boiler fitted and the plumber didn't connect up the controller, the boiler only works by the on - off switch.
I an an electrician but don't normally deal with central heating and need some advice on how to connect up the controller.
The boiler only has a L and N to it and it fires up if it has 230V to it.
The system then has two pumps - one for the heating and one for the hot water they both has thermastats. You get hot water or heating if you connect power to either of these.
The controller is a LP522 and the documentation shows pin 1 - 6.
I have connected 1 to N, 2 to L, 4 to Hot Water, 5 to CH. Is that correct? and where does the boiler connect to? Does it turn off if the hot water or CH pumps are both off? I would have expected a switched live to go to the boilere but thier doesn't seem to be any option for that. Does it connect to one of the CH or HW feeds?
Fred
Fred
