View the thread, titled "boiler with wall plate" which is posted in Boiler Advice Forum on UK Plumbers Forums.
H
heatybob
Can anyone recommend a decent combi boiler c/w wall plate to allow me to route the pipework up the back of the boiler,now heres the tricky bit, price wise up to £700.many thanks in advance.
you can buy a wall plate for any boiler that has one for a couple of hundred quid at the most but then you have to buy the boiler to suit obviously
Worcesters are about the only ones you can get the pipes up the back without using a stand off kit. Kits are available for most boilers for around 40 quid. They add around 40mm to the depth of the boiler.
You can run pipe work behind a main eco combi. Fitted several lately seem good value for money at 600 with clock flue etc. Can extend warranty to 7 years for extra 180 then again for 800 can get a worcester with 7 years warranty
you cant get a rear piping jig for a glowworm betacom a . the boiler comes with a 2 sided papertemplate one for boiler holes the other for jig but glowworm dont do the jig tried and told there is no intention to do one
ant
Ideal independent with stand off kit should come within budget.
Reply to the thread, titled "boiler with wall plate" which is posted in Boiler Advice Forum on Plumbers Forums.
