View the thread, titled "Boiler wont fire up" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Benj
Hello all. I have a baxi boston 2 60-rs and never had any problems up until recently. For the first time my gas ran out (i forgot to top up) and ever since then my boiler wont kick in. I can light the pilot light no problem and it stays on, the pump above is still spinning and eveything seems normal apart from that. Im thinking it must be something minor for it to be ok one minute, then gas cut off and now it wont boot up. And yes, i have put more gas back on! 😛
Thanks in advance if you could advise. Cheers.
I would get a corgi registered engineer to look at it if your not sure what the problem is and your not qualified to fix it...
I'v sorted it now, was something with the gas valve, replaced it. Everything seems fine now, Plumbers - piece of **** job! 😛 Should of gone into that trade! 🙂
thanks anyway
thanks anyway
Just for the sake of asking did you replace the valve?
Reply to the thread, titled "Boiler wont fire up" which is posted in Boiler Advice Forum on Plumbers Forums.
