M
magrumbles
my daughter has a potterton netaheat conventional system, with 2 tanks in loft and hot water cylinder. recently came home to find system not working. traced problem to a blown fuse in wiring panel . 🙂repleced fuse, 2 amp, boiler started but blew fuse in 2 seconds. byprocess of elimination found if disconnected pump , boiler started and fuse did not blow. replced pump with grandfos type. and all seamed well, apart from no hot water . moved diverter valve for hw manually hot water flowed heard lever returned under spring pressure. but now pump seems to work continually with boiler kicking in from timt to time. even with control panel set to hw and ch off. only way to stop it is to turn off mains supply. any ideas.🙁
