View the thread, titled "Boiler works ok on CH but goes to lockout when hw selected" which is posted in Boiler Advice Forum on UK Plumbers Forums.
armyash
Subscribed
Hi guys
Just had a call from a customer, the central heating works fine but as soon as he turns off the ch and selects hw, the boiler locks out and requires a reset.
Any ideas? I am unable to get there until tomorrow evening.
It's S or Y plan, could it be a faulty bypass, div valve or no pump over run??
Just a couple of ideas. Baxi Solo 380 PF
2 port or 3 port not opening would be my first port of call buddy.
no circulation, boiler over heating. check gate/ balancing valve is open on coil before anything else.
Gate valve on coil pipe is open but looks worse for wear, said i will change that.
With CH off at programmer, rads still get hot when just on hot water. Motorised valve does not seem to be working as i switch between the hw and ch.
When just on HW the pump makes a bit of a racket and the vent pipe gets hot, if i stop the pump then start it again i can hear water shooting out of vent pipe and the pipe cools down.
CH seemed to be working fine.
It's a circulation issue. If all valves are opening correctly then possible blocked coil. This may be an instance where the Bg favoured PF is actually needed.
Reply to the thread, titled "Boiler works ok on CH but goes to lockout when hw selected" which is posted in Boiler Advice Forum on Plumbers Forums.
