View the thread, titled "bonzodo" which is posted in UK Plumbers Forums on UK Plumbers Forums.
bonzodo
I have just joined this forum. I have a specific need. How to cut in successfully into a cast iron soil stack to insert a new soil connection. It is an edwardian house. Alternatively a reasonable priced plumber in brighton to do it for me,
Welcome to Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK!
Hello bonzodo, welcome aboard www.UKPlumbersForums.co.uk. Stick around, I'm sure you'll like the place. 🙂
Welcome to the forum bonzodo, I would first check that the soil stack above where you want to cut the branch in, is well supported and secure, if it is, I would then check that you could get a PAM bolted collar behind the pipe, if you can, I would use an angle grinder to first cut the front out of the pipe, so that you can get the angle grinder in to cut the back of the pipe then once this is done to the correct dimension for the branch, slide the branch in and then clamp up the two collars, top and bottom of the branch
Link to show you the collars etc
[DLMURL="http://www.saint-gobain-pam.co.uk/soildrain/index.cfm?page=%20Ensign%20BSEN877-182"]Soil & Drain & Rainwater : Ensign BSEN877 : Saint-Gobain PAM UK[/DLMURL]
Reply to the thread, titled "bonzodo" which is posted in UK Plumbers Forums on Plumbers Forums.
