boss on swan neck pan connector
View the thread, titled "boss on swan neck pan connector" which is posted in UK Plumbers Forums on UK Plumbers Forums.
H
handsomejackuk
Have a toilet installed with a swan neck pan connector... is it possible to solvent weld a strap on type boss to this..??
does it need to be strapped on or will the solvent weld be enough to hold it on... ??
or is there any other method of attaching a boss.....??
have very limited access, and was hoping to do this
anyone know if this is possible.. ????
I don't recommend it. Been to a few messy blockages with a boss from the basin tied into the toilet pan connector.
was hoping to use it for washing machine... via a upstand trap... dont look like the machine will fit now though....
Just enquisitive could it be done ?
i wondering whether to make provision, for when our washing machine breaks down we can get a slimmer one...
cheers...
Al.
you will probably have to hunt one down but a swan neck version of this is what you need Toolstation > Plumbing > Pan Connectors > WC Connector Inc Pipe Boss
try mcalpine products range.
why do you need it? only supposed to boss in a basin not anything else like shower or bath
Can you not drill through an external wall and connect into the stack. A proper job will be much better than what you propose.
Reply to the thread, titled "boss on swan neck pan connector" which is posted in UK Plumbers Forums on Plumbers Forums.
handsomejackuk,
kay-jay,
