Guest viewing is limited
Bottom entry fill valve for very low (almost no) pressure
View the thread, titled "Bottom entry fill valve for very low (almost no) pressure" which is posted in UK Plumbers Forums on UK Plumbers Forums.
dandiesel
Hi all,
I have a rather unique problem that I'm hoping someone could help me with?
I have built my own rain water haversting system to use to flush the toilet. I've used a side entry equilibrium float valve for the mains fill in my toilet cistern with sufficient air gap and weir overflow for when I have no rainwater in my tank. The rainwater tank is above ground on a raised platform outside, as the toilet is on the ground floor with flat roof above, I do not have the option of a header tank with water pumped from my rain water tank. Therefore the wc cistern is fed directly from the tank with less than 1 metre's head of water.
The flow to my cistern is very slow - approximately 1/3 litres per minute, this is not a problem for me. However my bottom entry ideal standard Univalve equilibrium float valve will not shut off. I have cleaned the filter, bleed hole, metering valve and diaphragm to no further benefit; there is an inline filter from the tank to prevent sedement causing a problem with the fill valve and the flow resitrictor has been removed on the valve's inlet.
Would I be right in assuming that there is insufficient pressure on one or both sides of the diaphragm to allow it to shut off the water?
Is there a float valve out there which would operate without pressure to open or close it? There is little room in the cistern and a ball float would not fit.
Without any other options I may have to save my pennies and invest in an on demand pump, although the cost of this may be more than I would save by not using metered water.
Appologies for such a lengthy post, I fully appreciate any advice given
Regards
Thanks to Dannypipe for the image in another post
You need something like the valves below and change the valve seat for a low pressure seat (red)
Reply to the thread, titled "Bottom entry fill valve for very low (almost no) pressure" which is posted in UK Plumbers Forums on Plumbers Forums.
dandiesel,
WHPES,
