View the thread, titled "Bristan Mixer Shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
GQuigley67
can anyone tell me how to get into this mixer shower to remove cartridge ? I'm trying to find it on the net the closest one to it is the "bristan java" but this seems like a newer style to the one I'm on about and the diagrams seem easier to remove the cartridge...
also the cartridges the customer have supplied are all different sizes and I'm not quite sure which one if even one does work with this shower
I've been tryin to get in through the back with a Ratchet and socket but it is really tight even with some wd40 and its now chewing the brass nut !
having troubles takin the 2nd handle off, cant get it off lol usually there are screws etc but not this one its held on by the brass thing in the middle
yeah I had to use 2 screwdrives to take away the small part that was holding on the control knob.
seems to me that all rubber washers inside are intact, only thing that caught my eye was the white plastic washer at the top which seemed to me like it was too big, so I wrapped some ptfe around it and around the top rubber washer and hooked it up to my shower hose and all seems fine now...
did the same mistake with that brass nut a few weeks ago, it dosnt come off..
the white ring washer will make the shower valve leak if not seated correctly.
there are three rubber 'o' rings on the valve free of charge from bristan delivery is around 3 days.
Reply to the thread, titled "Bristan Mixer Shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
