[FONT="]We have a British Gas 330 system boiler (not combi) which was installed about 3 years ago.[/FONT]
[FONT="] [/FONT]
[FONT="]Recently the boiler has been locking out (green burner light goes out) after running for about 10 minutes. This happens on hot water only, heating only or both. The system is S-Plan and all[/FONT]
[FONT="]diverter valves are working correctly. During the time the boiler is on the flow/return to the cylinder both get hot/warm and rads start to warm-up so I guess its not an airlock.[/FONT]
[FONT="]Additionally, the bathroom radiator acts as a bypass and this warms-up as normal.[/FONT]
[FONT="] [/FONT]
[FONT="]The F&E tank water level is correct and draining some water from a radiator caused the F&E tank ball valve to open so the cold feed is not blocked.[/FONT]
[FONT="] [/FONT]
[FONT="]I have today changed the 18 year old pump and this has definitely improved things (boiler stayed on for 30 minutes with temp stat on high) but the temperature[/FONT]
[FONT="]of the water circulating through the boiler is still getting hot far too quickly (up to 80C within 15 minutes from cold) and the boiler is still locking out.[/FONT]
[FONT="] [/FONT]
[FONT="]My only assumption now is that there is some debris (or blockage) in the heat exchanger restricting the flow which, if this is the case, I will call someone into to fix.[/FONT]
[FONT="] [/FONT]
[FONT="]Any helpful comments would be appreciated. Thank you.[/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
