A
avalassia
HI. I am not an engineer, but the customer. A cowboy has moved my B Gas 330. Untold problems with wiring have now been fixed. 2 Gas Safe engineers haven't found the fault, but my friend and I are trying to crack the problem, and, if necessary, ask a Gas Safe engineer to fix it. However, boiler cuts out with F5 after seconds, hot pipes. Is it possibly because flow and return pipe is longer now, by about 4 metres? How can it be resolved, please? Do I need a new pump? Thank you.
I recommend you advertise on this forum for a proper engineer to check your system out.
you gas safe engineer should not leave the boiler connected uncommissioned. So if its not been workinging from the move? it should not be connected to your gas supply?
either way you will need to get a competent person to take a look and commission the appliance according to the manufacturers instructions.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
