View the thread, titled "British Gas can't find a leak, but one of our rooms smells of gas" which is posted in Gas Engineers Forum on UK Plumbers Forums.
R
RandyTrouserman
Hi all,
we've got a smell of gas in a garage that's currently being converted to a bedroom. The gas pipes enter the house via a cupboard in the corner of the room.
British Gas have been out twice and we've had a Gas Safe registered engineer out, but no-one can trace a leak, either inside the house or outside on the meter.
The only advise that has been offered is to dig up the floor of the garage and our 50ft drive to see if there is a leak.
So I'm thinking I should really have a gas detector in there. Prices vary hugely, can anyone recommend one? Or even another course of action. We're getting desperate.
Thanks.
RT
Hi, the meter is 25 yards at the other end of the drive. It's actually outside of out property boundary. The chaps have all tested that but no luck.
Could that still affect the smell in the house?
Cheers
I don't know mate best reporting it on that number I gave you if you smell gas and they can't find it with their tightness tests etc im guessing it must be incoming supply pipe, as you can only test back to the meter not the supply pipe which supplys the meter if you know what I mean. Their tests only prove there is not a leak in your pipework so it must be the suppliers pipework underground.
Hiya,
their pipework finishes 25-30 yards from my house at the meter. I'm told that up to the meter is british gas's reponsibility but after that it's my issue - and this is where it's been suggested the drive is taken up on the off chance that their could be a leak.
Am I right to presume that if the leaks is before the meter (ie down the other end of the drive), it wouldn't smell in the house?
Sorry to sound thick.
RT
doubt full to be able to smell it from that far away and if you could it ones hell of a leak and smell would get stronger the closer you get to it
Try turning all gas appliances off and viewing the meter reading then checking the meter reading an hour or two later
Ensure no pilot lights are lite on boiler also when you do this
Will do Tom, thanks.
There no smell at all from outside, so I'm presuming the pipes leading to the meter are sound.
If I turned everything off for a day and there was a leak, would I notice a difference in the readings or does it have to be a longer period of time?
Ta
When you say " no one can trace a leak" do you mean that bg and engineers tests show there is no leak on the pipework or their tests show there is a leak but they cannot locate it?
I once evacuated a sheltered housing complex because of a smell of gas. The same thing, drop test on house okay. But still smell of gas.
BG came out and we checked the adjoining properties, no leak, but still smell of gas. It was eventually found 1/4 mile away under a road.
You just don't know do you? In your instance, if you test your pipework from the meter back into your house and it shows no leak, then its got to be somewhere else.
Thanks Bernie, I think!
We have a couple of foot of pipe work coming up out of the ground into the house, then our internal pipework - it splits to the boiler and the oven.
If it's not in that little lot, does that mean the drive has to come up? Or is there a test above the ground that shows where a beneath the ground leak may be?
Cheers
Bartdude,
They've been out twice before and tested and found no fault, I open the windows as they say and so there's no smell when they come round.
What can I do to force their hand?
RT
I was told, it was over to me and I had to get a Gas Safe engineer out. Did this, at my cost and he said he couldn't find owt.
I'm concerned that BG will say it's my issue again and I have no other option but to take the drive up. I know it's going to be small change compared to the house going up, but it'll cost a small fortune and there's no guarantee that's where it is.
Can I ask BG to do something different than the normal tests? They draw blanks.
Cheers
The gas safe guy must of done a test at the meter I'm guessing there was a drop on his manometer, otherwise why would he say to dig up your drive?
Can you get him back to cap the pipe going into your house and just check the pipe running under your drive before doing anything drastic otherwise your going to have to start shouting at BG threaten to report their engineers to the Health and Safety Executive for leaving you in a dangerous situation
if your pipework has been proven to be sound and safe then call transco who pipe the mains gas and report the smell of gas to them, they have to respond. BG is no longer the carrier of gas just a supplier if that makes sense so they dont care once they have checked their meter is ok.
Thanks chaps, think this will come down to me having to shout to get heard.
Sorry it was Tranco that cams out, not British Gas, getting my utilities mixed up there.
Have just spoken to a friend of a friend who's a plumber and he says the utilities have overground sniffer devices that they use. Saves me drive being dug up.
Thanks again, I'll report my findings.
RT
if the engineers have proved none of your pipework/appliances are leaking, and transco have checked their supplies get in a friendly plumber with a sniffer to make you feel better, then if thats clear buy an a freshener and stop worrying.
There's a thought, we're not on mains drains, we've a septic tank.
Could it be from that?
methane doesn't have a smell they add a chemical to it to give it that distinctive smell so you can detect a leak.
it wouldnt be the first time a gas guy has been called to a "smell of gas i think" for it to be traced to a broken drain with the sub floor completed flooded with raw sewage, given the work all ready carried out, and the fact there is a smell, it MUST be coming from somewhere,
i appreciate that, but the transporter adds "something" to piped gas so we can smell it, and we add "something" to our gas and as a by product when you are near a choked manhole you can smell it as well, either way up it is possible a broken drain or dampness is causing the smell
I once had the corgi inspector to a house after the owner could smell gas but there was no drop on the test, turned out to be some dog food that had gone off, apparently rotton veg can also give off a gas like smell, have you stored any food in the garage in the past, just a thought.
Reply to the thread, titled "British Gas can't find a leak, but one of our rooms smells of gas" which is posted in Gas Engineers Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
RandyTrouserman,
andyplumber,
