View the thread, titled "Britony Combi 80 SE. Help please." which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Mick Stupp
Well! Basically I am having a battle of wills with my 8 yr old Britony combi 80 SE boiler.
It suddenly started (well not quite suddenly, it just started and got worse because I just put bigger bowls underneath,) leaking. It eventually seemed to be leaking from just about every point that you can think of. I am not a plumber, but I am an extremely competent D.I.Y.er. I have also worked in the motor trade, and am pretty much a hands on type of guy.
So far I have replaced most of the seals. the valve in the right hand hydraulic block, and the complete left hand hydraulic block. I really thought that I had cracked it tonight, but... It is leaking from the air separator valve on the top of the plastic pump housing. I know that I can buy a replacement for it but... I just can't fathom out how to get the damned thing out. I am loathe to get too heavy with it, in case I break the plastic housing, thus needing to buy a complete pump. I am unemployed, so basically I cannot afford to just go out and buy a new boiler and have it fitted, (much as I would like to.) I think that when we were sold this boiler, we were sold a "pup."
So if any of you guys could help me, I would be extremely grateful.
The auto air vent/separator just unscrews from pump housing,once you get new part,you will see
Many thanks for your reply.
Maybe I was just being too careful, afraid to break the housing...🙁
Edit. Now that I know it unscrews, I just attacked it again with waterpump pliers and it came out.
I was afraid to try too hard before, because I wasn't too sure if it unscrewed or was fastened in by some devious means...
Thanks very much for the info...
Reply to the thread, titled "Britony Combi 80 SE. Help please." which is posted in UK Plumbers Forums on Plumbers Forums.
