View the thread, titled "Britony Combi SE 80 - Boiler problem" which is posted in Boiler Advice Forum on UK Plumbers Forums.
T
tedson
I've got a small problem with my combi boiler. When the heating is off, and i run the hot water, 2 - 3 minutes after I've stopped running the hot water, the boiler starts to fire up for a second then cuts out, and repeats this process over and over again until I press the reset button. I doesn't happen when the heating is on.
I've contacted the manufacturer's technical help team via email, but they say they have never heard of this fault before. I was just wondering if anyone here might have any experience of this kind of thing.
Regards
Ted
It best to contact the boiller Manufacturer and ask to book an appointment for their service team, they will charge a fee, but it may be the best option and hopefully a quick repair.
I have a similar problem with a Britony System 60 boiler, but it's my central heating that cuts out... Anyway I had problems previously with the hot water too. Possible causes... i) Is the water pressure high enough? If it's less than 0.5 bar you need to top it up. If your system's the same as mine there will be a tap on one of the pipes that you can open. Watch the pressure guage and close the tap when it gets to 1.0-1.5 bar. (If you let it go higher your boiler will vent water out of the overflow pipe.) If the pressure doesn't rise there may be a problem with your mains. If it falls again there may be a leak. Or you may have a problem with ii) the pump, iii) one of the magentic flow switches or iv) the three way diverter. I'm still researching those, because that might be what's causing my problem... Anyway, let me know if you find the answer, and I'll do likewise!
I just re-read your post more carefully, and it's not the problem I had. The 2-3 minute thing sounds like the TAC delay. So the boiler's firing up, decides there's a problem, shuts off, waits 3 minutes, and tries again. So you need to figure out why it thinks there's a problem. Could be quite a few different things, but if you get HW and CH fine when the CH's on that rules out most of them. Anyway, I don't think you're monitoring this so I'll leave it there.
For anyone who had a problem more like mine, download the User and Service Manuals from the C&M website, then isolate and drain the boiler (it's easy), remove and clean the CH return filter, remove and clean the flow switch, and only worry about the 3-way diverter if it's used on your model (i.e. there are 3 pipes going into it) which it isn't on mine. Refill the boiler, and see if it works ok. If you're feeling extra diligent, you could repeat this process to clean out any debris that was flushed out when you refilled. Hopefully that'll solve the problem. It did for me.
If not, but you're getting either HW or CH ok, then the heat exchanger is fine, so the next most likely culprit is the PCB. Replacing that looks a bit fiddly but not impossible.
Good luck!
Reply to the thread, titled "Britony Combi SE 80 - Boiler problem" which is posted in Boiler Advice Forum on Electricians Forums.
