View the thread, titled "BTW Toilet Connection" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I’d be more inclined to bring up a solid 90° bend and then go straight into it with a straight pan connector. Pan connector to pan connector is not a great idea
From reading the links that extension is designed to fit directly into pan connectors so if it gives you the 100 mm then I don’t see an issue
I’ve just looked at your link again and it’s brought up an entirely different part this time (sorry I must’ve been looking at the wrong thing). That would work but I’d put something behind the 90° fitting to make sure that the toilet inserts correctly.
Thanks I like the idea of the solid 90° bend with the straight coupler, do the 90°solid bends come with a push fit into the existing soil pipe or would It need gluing?
That’s where I’d try and go for a little rigidity. And I meant how much you have accessible to you
Reply to the thread, titled "BTW Toilet Connection" which is posted in Boiler Advice Forum on Plumbers Forums.
