Piratepete
Anyone got experience of these boilers?
It suddenly stopped working -(water)flow sensor fault. Bosch engineer replaced both flow sensors. Boiler now works but doesn't heat the water in the rads above 50 degC. Also howls now when it starts up. Bosch engineer says that I've got a water flow problem, but the pump is running ok, you can hear the water rushing through the pipes. On HW only it takes an age to heat the water to 55deg.
I still suspect the boiler. Any idea how I can prove it?
Cheers
Pete
Cheers
Pete
