Y
yonner
the boiler is in the kitchen and the tank is being moved into the loft there is two pumps one for the heating obviously and an other wich seems to pump hot water around my taps
I've got two like that (both large hotels) plus a large manifold arrangement for hot and ditto from the header tank to work all the pumped showers!one of my customers has a combi with 54mm DHW and the return line in 28mm
explain that one to me again oilman, how do you have a 'combi' with a flow and return. even if it was just a combi and somehow pipework upped to 54mm the pipework would contain about a litre every foot of pipe. if his bathroom was 10 metres away, that would mean pulling 30 odd litres of dead legged water before it even starts to get warm, and a current boiler rates would mean about a 3minute wait !!
Sounds like a thermal store cylinder to me!oil boilers are different, They are cast iron and hold a lot of heat in their construction, this boiler contains a store of DHW which is fed into a blending valve at 60 degrees circulated and returned to the boiler by a brass Grundfos and re-heated, so because the water is circulated it is local to every tap so minimal water is wasted and the boiler maintains the heat of the circulated hot water. The cold water to the boiler is gravity fed.
Reply to the thread, titled "can anyone identify my cenral heaitng system" which is posted in UK Plumbers Forums on Plumbers Forums.
