View the thread, titled "Can I run 2 gas boilers off the same gas supply ?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
depends on what meter you have also depending on what kw appliances you are planning for
Thanks for the reply.
That's what I thought.
How do I find out what the max output of the supply is?
Is it stated on the gas meter?
Then I assume that the boilers will state what supply they need ?
Is that it, or is there any formula that needs to be applied?
eg: Is it just that both boilers total usage must be within the total output available from the meter, or does there have to be some % less?
Can both boilers be fed from the same gas pipe, or should there be two seperate pipes tee'd off from the meter?
Many thanks
Yes should be in m3/h
Correct 30kw and a 30kw water heater will be fine or 40kw and 20kw etc
Correct total needs to below rated capacity
You can supply both from the same pipe but needs to be sized correctly
Reply to the thread, titled "Can I run 2 gas boilers off the same gas supply ?" which is posted in Boiler Advice Forum on Electricians Forums.
