M
Matt from Derby
I moved into my house 4 years ago.It has a Worcester 28cdi combi.It has worked well and i have never put any water back into the system but now the guage reads 0.2.Oops.I have watched a video clip on you tube explaining how to refil the system,i have inserted the white plastic key (and turned it) however when i open that infeed water valve thing you can hear the water start to move but then nothing,the dial does not move.When i remove the key there is a little bit of water there but only a tiny amount,is this because the water is not progressing past this point? and do i have to do this refil whilst the boiler is in operation like with a hot water tap on or with the radiators on.I know that i should have sorted this problem a while ago but to me if it works i don't touch it.I learn by my mistakes and always the hard way.Any advice would be much appreciated.Cheers Matt
