View the thread, titled "Can only get hot water or heating" which is posted in Bathroom Advice on UK Plumbers Forums.
mutley racers
Subscribed
So I have been called to a s plan system which will only give hot water or heating. Not both at the same time. Only 240v coming from on at the programmer 1 at a time when both calling. New programmer needed I think?
Cheers fellas
Yep if your only getting one live from the prog then prog has failed test by temporarily removing the prog and link the wires
Sounds like a programmer fault. Do what Shaun has suggested to test it.
Thanks Matt. Will do
Update on that Church job we looked at. They had a company from Manchester come and install a few fan heaters and 2 boilers for 40,000. No heat replacement fans or even wiring the controls. A separate company did the wiring.
Reply to the thread, titled "Can only get hot water or heating" which is posted in Bathroom Advice on Plumbers Forums.
