yes,provided its only the motor thats gone,or even the syncho
The replaceable Honeywell heads have a small round lump on the metal cover - the fixed ones don't.
Blod
its a pretty big system and can see it'll take ages to refill so dont wanna drain down if i can avoid it.
last resort is bunging cos youll have 3 open ends to deal with when bungs let you down
Hi, new to the forum. Anyway, have you never heard of "bunging it" & creating a vacume? I have an aqua vac & rarely drain a system to change a valve. Admittedly, a 28mm 1 may get the adrenalin going 😱 if it's a tight fit in the pipe-work. Who needs substances when there is adrenalin anyway
then turn gate valve off on cylinder return
3-2=1
turn all rads off
3-3 = 0 😱😛😉
never found a gate valve on cylinder return yet!! must just be a birmingham thing!!
yeah i would normally bung it mate...but would'nt trust it on 28mm!!
anyways....update on the situation....never had to change the valve in the end as it seemed to be working ok when i got there and not heard nothing since....silly custurds.
good advice by all though and duely noted. cheers lads.
Reply to the thread, titled "can you just replace the head on a honeywell motorised valve" which is posted in UK Plumbers Forums on Plumbers Forums.
