View the thread, titled "Can't clear this air lock" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Dan Masey
This is the hot fees from gravity fed cylinder. It tee's off as you can see to a shower pump just below. Iv got a air lock on the hot water that I cannot shift. Iv connected hot/cold washing machine taps together and tried to blow it through but nothing. Any ideas??
There should be another draw-off on the top of the Cylinder for the domestic side. How do you know it's an air-lock? How many draw-off points are effected? Does the water just stop running? Bit more info Dan please as what you show is an Essex flange connection into the side by the looks of it! Normaly the rest of the taps for the house are taken from a top connection 🙂
2 basin taps upstairs and a down stairs kitchen mixer tap. Runs for about 30 seconds then splutters air out and stops. I'm not 100% it's an air lock. I'm wondering if the gate valve is faulty.
I got called to the job and previous plumber had connected the pump to the vent pipe. Couldn't believe it actually dragged any hot water through. Tiny tank on loft as well. So Iv installed new pump, new 50gl cold water tank.
Turns out it wasn't an airlock. The gate valve was wrecked. Installed a lever valve it and seems fine now.
I did pump cold water back through the hot pipe until it came out the vent pipe in the loft. It still did not solve the problem. That's when I decided to renew gate valve. Fingers crossed that's solved it.
Yep agree it needs to be 450mm from the top. Shocking instal. ImageUploadedByTapatalk1360948372.114778.jpg
The customer is claiming back the massive amount that the "electrician" apparently fitted. It was an electrical firm that had a plumber on board. Lol. Crazy what some people charge / get away with.
Yep agree it needs to be 450mm from the top. Shocking instal. View attachment 10967
Blimey give everyone else a chance for Job Of The Month
Reply to the thread, titled "Can't clear this air lock" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
