A
Aaron Newman
I have found. Leak on my toilet inlet the plastic bit that mets the isolation valve so decided to change the valve. Problem is now I can't get a water tight seal form where the plastic meets the valve. I have done everything but no luck.
any ideas' flexible hose?
I put a new washer in, have to say did not wet it but still water every ware. I also had to cut the plastic a little as it was a little worn. Should I just replace the whole thing.
If it's bottom entry you need one of these...
Fluidmaster Brass Shank Bottom Entry Fill Valve | Fill & Flush Valves | NoLinkingToThis
Or this for side entry...
Fluidmaster Brass Shank Side Entry Fill Valve | Fill & Flush Valves | NoLinkingToThis
Thanks for the help as only new on here. Do you think the lsx stuff will work as it seem more of a spurt rather thn a dribble (sort not best explained) also the inositol valve is not the normal type it come up a bit at the top but also unscrew which also leaks if not tight.
Lol. Can I use that lsx stuff? Oh and it's not a normal isolation valve it's one with a longer top and that also unscrews which also leaks if not tight. Will post a pic of inside.
Remember what I said about flexis? Goes double for LSX.
It's a normal valve.The fluidmaster will easily fit.
Why did you undo it in the first place?
That's a ball valve called Chem. I notice it has the supporting plastic bolt missing which can risk it levering & cracking someday. Either fit a brass female fitting ptfe taped onto the stem, or replace the whole valve. Chem are cheap as chips, but I would do as others said & use a brass shanked Fluidmaster or similar.
I forgot to say that I use flat rubber washers instead of the fibre ones.
They are for some of the plastic tap fittings (think Hepworth) but are identical size & will provide a good soft seal against the plastic stems & shouldn't rot like some fibre washers.
bit confuesed, so I can just remove the old one and fit the fluid master one and all should be good. And it does not need the chem bit.
