Capping off rad valves..
View the thread, titled "Capping off rad valves.." which is posted in UK Plumbers Forums on UK Plumbers Forums.
WaterTight
Subscribed
..while rad is removed for decorating.
You know, in case TRV frost setting kicks in.
Schoolboy question I'm sure but.. what do I actually want to put on it?
A 22mm cap won't fit will it? Isn't it 3/4? (if it's not half inch..) I'm guessing it needs to be a 3/4 cap? And what do you use for the rubber washer disc inside? Does it have to be a specific rad capping off cap that you buy or do plumbers rig something up?
For the 1/2" valves use a half inch compression nut. Drop a 5p in and a fibre washer (tap adaptor washer).
For 3/4" use the nut off a rad valve tail with a 10p and 3/4" fibre washer.
You can buy the real Macoy if you want from any merchants. Just ask for 1/2" or 3/4" bsp brass caps.
for temp capping of rad valves when rad is removed recycle those old washing machine hose ends by cutting thon of and stuffing in the pars box, hammer down the crimped end or cut some rubber washers out of an old bike innertube. you can actually pry of the hase bit from the cap then use the cap with a 2p and bit of tube to cap off leaking dis-used w/m valves too.
TRV's are supplied with a decorators cap, remove head and screw cap right down, this eliminating the frost protection kicking in
TRV or conventional rad valve don't matter a tuppenny bit. Always, always, always cap off.
1/2" caps for 1/2" valves and 3/4" caps for 3/4" valves. Just black iron caps, don't worry about brass. Couple of winds of ptfe and Bob's your aunties live in lover!
Couple of quid and no messing about with 5p pieces or modified hose ends!
Tight fisted lot! lol
Reply to the thread, titled "Capping off rad valves.." which is posted in UK Plumbers Forums on Plumbers Forums.
WaterTight,
Dotty,
