View the thread, titled "cast down pipe repair" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
dean4drains
i have a split cast iron down pipe (kitchen and wash hand basin waste) to repair, its split where it goes through concrete floor hence waste is seeping out, i was thinking about cutting out 50/75mm around around the pipe, patch split with some kind of epoxy, and replace concrete but chamfer up the pipe a bit to protect epoxy.
Other option is to replace cast pipe but its a 1.2m dig down through concete floor with a branch coming into it and or same but put plastic back.
any ideas.
Cut out around it and fit a collar to the cracked piece, link to help you
[DLMURL="http://www.saint-gobain-pam.co.uk/soildrain/index.cfm?page=%20Ensign%20BSEN877-182"]Soil & Drain & Rainwater : Ensign BSEN877 : Saint-Gobain PAM UK[/DLMURL]
thanks, i was thinking down this down this line, but think the branch might get in the way, still to do a bit of mesuring.
Reply to the thread, titled "cast down pipe repair" which is posted in Air Sourced Heat Pumps Advice Forum on Electricians Forums.
