might be worth going on a training day
Its on my todo list, just waiting for the training truck to be local.
Might go on the factory tour at the end of the year.
I fitted one the other day and I agree, they could of been designed better. Why design a boiler that needs to be taken apart to put on the wall? Just a hook on type would do. They aren't that heavy.
Nice one ShaunCorbs, just found that Regin tube, looks good.
REGIN RIGID MANOMETER TUBE REGU03: Amazon.co.uk: DIY & Tools
yeah it does look good but why does it cost £13 plus postage
Could not agree more they are a heap o shart.Fitted my first WB CDI Compact yesterday and today.
Never again!
what a ball ache, everything's so fiddly.:banghead:
How is it well designed when you have had to work out a particular order and method just to get it installed. Why not just fit a boiler which is well designed and doesnt make you work out how to get around a bad design.With the circlip for expansion vessel remove the syphon and use long nose pliers.
For the prv connection swing the cold water connection to the left and enables you to use grips to tighten up the brass connector.
The case seems strange at 1st but is really easy afterwards. I have fitted loads and never had a issue with call backs ect.
It's easy to remove expansion plug before hanging on the jig... No need to move condense trap as you only need to reach in & push it back when the vessel is dropped in!
The PRV has a special shaped thread, it seems designed to be able to do up hand tight! So no worries there!
You can't make a boiler that compact & please everyone 😛
I agree fitted one last month. Rear piped it what a fuss fitting pipes to rear I made do they could be removed from fittings under neath. Come to hang boiler and pump housing fouled pipes. But if you make tails longer you can't remove them when boiler is on the wall.. Eg if you pipe up tails with clip space upward pipes foul pump housing. If I ever fit another one I will get pre made tails
Reply to the thread, titled "CDI Compact" which is posted in UK Plumbers Forums on Electricians Forums.
