Central heating overactive!
View the thread, titled "Central heating overactive!" which is posted in Central Heating Forum on UK Plumbers Forums.
M
ma701ss
We had a radiator fitted a few days ago. That evening and since then, when the hot water has been on in the evening there seems to be more "activity" with the pipework. As I understand it, the same water flowing through the radiator pipework diverts and heats the water in the cylinder when hot water only is on. The pipework near the cylinder and boiler that has the multihead and Magnaclean attached is flowing and getting hot. I suppose this is what it should be doing, as the multihead is the pump isn't it? It's just that I've never noticed these working before when hot water only has been on, as they are so loud. It seems that something is different since the radiator has been fitted.
On a different subject, one radiator pipe was disconnected and capped off with a push fitting and left under the floorboards, so there's a deadleg of about 6 inches coming off the main run now. Is this good practice, as I wondered if the flow would be affected or if it's good to have a fitting like this that could potentially leak without us knowing?
A new smaller radiator was put in so theres a new pipe branching off and a deadleg where the old pipe is.
If the system was drained to put a smaller rad in it would have been sensible to remove the old branch , push fit under the floor no thanks !
Reply to the thread, titled "Central heating overactive!" which is posted in Central Heating Forum on Plumbers Forums.
ma701ss,
Toddyplumb,
