Central Heating Radiator Use
View the thread, titled "Central Heating Radiator Use" which is posted in Central Heating Forum on UK Plumbers Forums.
Dave Heating
This question is related to a 5 bedroom property, with a radiator in each room. Whereby heating is turned on/off in bursts of 2 hours (2 hours on, 2 hours off). 3 rooms are used constantly and 2 (smaller) are not. Assume the house is well insulated.
A DIY family member believes that heating the whole house is the better option, however I am under the impression that turning the radiators off in the 2 rooms makes more sense. DIY family member argues that in the 2 hours off period the house will cool down much slower if the whole house has been heated. I however argue the cost implications outweigh the probably negligible slower cool down?
Views on this?
As an additional question would leaving the doors of those 2 (smaller) rooms open/closed make an impact?
Hope that makes sense.
Many thanks.
If the house is well insulated, then turning 2 rads off won’t make a difference to cooling.
It’s one of them if sealed off from the rest eg door kept shut your right but if the door is being opened then it will passively heat via connecting rooms eg hallway which will increase the load on these
Reply to the thread, titled "Central Heating Radiator Use" which is posted in Central Heating Forum on Plumbers Forums.
Dave Heating,
ShaunCorbs,
