View the thread, titled "Central heating - timer fault or something else?" which is posted in Central Heating Forum on UK Plumbers Forums.
Noticed that when we turn the heating on manually we would then notice it had gone back off again so set to continuous and saw this
video has sound
Does this look like a faulty timer or something else tripping it?
Definitely doesn’t look right. What make of timer is not? These are normally quite easy to change if I’m honest.
Please like this post if you found it helpful.
Its a Honeywell, if it needs replacing I may well go down the smart thermostat route
thanks
[automerge]1569968843[/automerge]
If I wanted to change for another standard type timer are they all pretty compatible as this one looks hard to get
[automerge]1569968965[/automerge]
just seen I can swap it for a st9400a
[automerge]1569969095[/automerge]
last note, it doesn't do it when the heating isn't on
Reply to the thread, titled "Central heating - timer fault or something else?" which is posted in Central Heating Forum on Plumbers Forums.
