A
Adam Everitt
Hi everyone, first post on here but please excuse the brief introduction. My girlfriend and I just recently bought our first house and my plumbing experience is roughly 3 months of playing, breaking and fixing.
new years eve one of our guests decided to mess about with the timer for the central heating / hot water. I've ended up having to reset my timers (device is Wickes RWB9.cw and I've been unable to find a manual for it) everything has been reset just fine however the timer won't allow me to turn the hot water off until the central heating goes off. Here's my settings to help explain
CH. On: 7am - Off: 9am.
CH2. On: 5pm - Off: 10pm.
So I try to set the water to heat up the tank once from 4am - 5am but the timer flashes "LIMIT" when I try to make it turn off any earlier than 9am (i.e. when the CH goes off)
quite confused by this because I'm sure that before I had to reset my timer I was able to pick and choose when I turned my water off regardless of when the CH is timed.
just wondered if any of you guys could confirm that the CH needs to be on for the HW to warm up? I'm not sure how all this works and as I mentioned I can't remember what it used to do before the reset.
Thanks so much in advance, Adam
Thanks snowhead for finding that. So it appears we're on a gravity system and the central heating cannot be operated without the HW being on.
A further question, does this mean I'm constantly heating water or will the boiler cease when the water reaches the temperature on the tank thermostat?
cheers, Adam
If your system is fitted with diverter valve or two zone valves you could alter the dip switches on the back to enable independent operation. If the system is still running with gravity you are stuck with it. Time for an upgrade?
