M
Mtbamplumb
Hi all,
Have a problem with several of my radiators that had been plagueing me for the past couple of months.
Summary:
Actions already taken:
Main problem radiator(kitchen) only seemed to get to work for couple days by turning all other rads off, draining water from drain valve, leaving thermostat valve closed and check valve open, bled radiator until was full of hot water.
ANY SUGGESTIONS ARE GREATLY APPRECIATED.
regards
Mtbamplumb
Summary:
- 4 radiators on same loop fed from 1st floor
- 2 on first floor (landing & Livingroom)
- 2 drop down to ground floor(entrance hall & Kitchen)
- 3 intermittent (entrance hall, landing, living room- worst of 3)
- 1 very very intermittent, only work for a couple days then stop (drop down to kitchen)
- all other rads get piping hot, and when check valve opened only a little get hot and maintain temperature
- 3 story house
- grundfos UPS 25-55/ 180 pump
- tried balancing the system, 3 of 4 started to get warm, 1(drop down to kitchen) will not warm up
- Bled all rads numerous times
- fully drained and refilled system, re balanced
- drained biggest problem on , Kitchen rad which has drain and topped up system to see if air lock, got warm but didn't stay warm
- Replaced thermostat valve on kitchen rad.
- flushed system with hosepipe, and tried also flushing each rad in turn by closing all and having 1 open at a time.
- removed 2 problem radiators and jet washer flushed to remove sludge
- took pump off and checked impellers
- Pushed up pressure to 2 BAR to no avail
- pump set on maximum speed setting
regards
Mtbamplumb
