L
Leoki
Laying flow and return pipework in a 2 bedroom flat above a shop in readiness for a gas safe engineer installing and commissioning a condensing combi. The flow and return pipes off the boiler are 22mm. Would it be okay to reduce to 15mm barrier pipe at the floor to run the flow and return run to the rooms with the rads. 8 rads in total, combined 11.5 kw output.
Does anyone recommend a particular barrier pipe, e.g Hep or Speedfit. I understand Hep is quiet flexible but difficult to de-mount if you make a mistake and need to redo a connection. 🙂
